143 Users Online (142 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> scheduling height of irregular curtain wall panels
Tue, Jan 4, 2011 at 4:19:26 PM | scheduling height of irregular curtain wall panels
captaincarlisle
I'm attempting to make a schedule for curtain wall panels that are not exactly rectangular.  I would like to have a height and width but once the panel is cut into or made into a triangle I can't get any values for height or width, but only area.  I am using the curtainwall for steel panels that have openings cut into them and would like the max height from top to bottom to show up on the schedule.  Right now the only value I get is area.  Can anybody help?
Tue, Jan 4, 2011 at 10:43:55 PM | scheduling height of irregular curtain wall panels
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Only really solution would be to elevate it and dimension...  Unfortunately this is just how Revit currently works with irregular curtain panels.
Another solution would be to create an adaptive point based family with reporting parameters bound to shared parameters and host this to the curtain panel then schedule those points.  But probably overcomplicating things a bit...
Regards,
Chris.
Mon, Jan 10, 2011 at 3:54:52 PM | scheduling height of irregular curtain wall panels
captaincarlisle
I've been messing around with the latter solution of creating an adaptive point based family.  I assume this is either a curtain panel pattern family or the adaptive component.  I've created the panel pattern or adaptive component with the parameters but am having trouble hosting it in my curtain wall assembly.  All of the tutorials I've seen show it being hosted into a conceptual mass but when I try to host it to a curtainwall it wants it to specifically be a curtain panel.  Any suggestions?
Sun, Mar 11, 2012 at 12:08:01 PM | scheduling height of irregular curtain wall panels
Alvasin
Is there any way to get a curtainwall/storefront door into my door legend? I tried to place it, and it said I had to enter a dimension, but the only thing it would let me do is 3'-0" and it looked like a square panel. I changed it to 7'-0" after placing it, and it just changed to a 7' square (the door's glass panel and elevation swing).
Wall Panel Systems
Schedule dimensions of non-rectangular curtain wall panels.
Sat, Aug 13, 2011 at 8:59:36 PM
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:58 AM
Retaining Curtain Wall Door Scheduling Data
Thu, Jan 8, 2015 at 2:47:09 PM
Scheduling "System" Curtain Walling Panel Parameters
Thu, Aug 28, 2014 at 9:35:37 AM
Can Adaptive Panels Be Used in A Curtain Wall
Mon, Jun 9, 2014 at 1:49:37 PM
Page generation time: 0.8355
