87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Is it possible to make a line-based family wall based?
Tue, Jan 4, 2011 at 12:12:08 PM | Is it possible to make a line-based family wall based?
jmqrsq
5 Stars: 3 Votes
So I am trying to create a bar handrail for corridors in a project. I first created a lone based family so I could snap to autocad drawing imported as a template. works great with one exception, it will not host to a wall so it can move with it. The only solution i have found is to align and lock it to the wall. kind of tedious. So the I tried to nest that family into a wall based family. works except I lose the ability to draw a line on the wall to create the bar that i need. It always comes in as the base length of the bar. is there any way to make this do what I want? Thanks
Jaysyn
Tue, Jan 4, 2011 at 4:04:58 PM | Is it possible to make a line-based family wall based?
pchan
pchan Avatar
5 Stars: 5 Votes
The short answer is no
Tue, Jan 4, 2011 at 10:52:18 PM | Is it possible to make a line-based family wall based?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the Structural Library there are families for stiffeners etc, that have this capability.  That is they will host to a face, as well as be line based.
Use one of these families as a base and edit it.  I'd have to check but it might simply be a matter of checking a check box to enable this functionality.
Regards,
Chris.
Tue, Jan 4, 2011 at 11:16:35 PM | Is it possible to make a line-based family wall based?
pchan
pchan Avatar
5 Stars: 5 Votes
Mr Spot,
Just curious, I tried to look for the stiffeners family from the RAC library and couldn't find it.
Is this kind of family only comes with Revit Structure?
to Jaysyn,
To get back to the original question, the line based family should now have three options when you first place it in the project, you can choose from  place on vertical face, place on face and place on workplane. When choosing place on face, you should be able to host it on the wall like any other hosted family, the catch is you will not be able to place from plan view (I did it on 3D view) so, when the wall moves, the family will move with it.
One other thing you need to be aware of is that the ref level of the line based family will be the host face.
Philip
Wed, Jan 5, 2011 at 12:08:05 PM | Is it possible to make a line-based family wall based?
jmqrsq
5 Stars: 3 Votes
Mr. Spot, I would be interested in knowing where to get that base family and if the category can then be changed to furniture or specialty equipment.
Phillip, not sure what you mean exactly by your last sentence.
Thanks for all your help on this.
Jaysyn
Wed, Jan 5, 2011 at 12:43:31 PM | Is it possible to make a line-based family wall based?
pchan
pchan Avatar
5 Stars: 5 Votes
Jaysyn,
 "One other thing you need to be aware of is that the ref level of the line based family will be the host face."
What I meant was when you place the line-based family on the wall, the bottom side of the family will be the hosted face on the wall. In a normal situation where (ref level/plan level) will be the bottom face of the family.
In you case, when you are trying to make a bar handrail as a line-based, you should create the geometry rotated so that the bottom (the mounting face of the rail)  can be hosted on the wall.
Hope it explains your question
Philip
Wed, Jan 5, 2011 at 1:00:22 PM | Is it possible to make a line-based family wall based?
jmqrsq
5 Stars: 3 Votes
ah gotcha.
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:38 PM
Line Based Wall Rebate Family Question ?
Fri, Mar 28, 2014 at 1:18:49 PM
Revit 2013 family from wall based to flor based
Mon, Feb 4, 2013 at 6:56:52 AM
line based families to align to curved walls
Thu, Jun 8, 2017 at 9:53:57 AM
3D line based hosted family template or solution
Sat, May 2, 2009 at 1:46:18 PM
Page generation time: 1.7736
