67 Users Online (66 Members):
Forums >> Community >> The Studio >> adding floors
4 Posts No Rating |
Hello, i am a student and want to learn how to put in floors. If you can help please write back. Thanks if you do.
From the HELP file .... Learn to use it because it will answer qustions like this.
Adding Floors
- Click Home tab
Build panel Floor drop-down Floor.
- Draw the floor boundaries, using one of the following methods:
- Pick walls: By default, Pick Walls is active. (If it is not active, click Modify | Create Floor Boundary tab
Draw panel (Pick Walls).) Select walls in the drawing area to use as floor boundaries.
- Sketch boundaries: To sketch the profile of the floor, click Modify | Create Floor Boundary tab
Draw panel, and select a sketching tool. See Sketching.
The floor boundary must be a closed loop (profile). To create an opening in the floor, you can sketch another closed loop where you want the opening to appear.
- On the Options Bar, for Offset, specify an offset for the floor edges.
NoteWhen you are using Pick Walls, select Extend into wall (to core) to measure the offset from the wall's core.
- Click
Finish Edit Mode.
Adding 3rd floors to projects |
Sun, Dec 16, 2007 at 7:38:19 PM
better floors |
Fri, Jan 28, 2005 at 11:18:25 AM
My wishlist: Adding parameter in VIEW TITLE rfa |
Tue, Mar 20, 2012 at 4:55:00 PM
Adding a floor around precast columns |
Wed, Sep 21, 2005 at 5:50:29 PM
Adding a second floor into a six story building |
Thu, Aug 21, 2014 at 12:02:52 PM
Members: | 2017271 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
