134 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Schdule of Beam System
Mon, Jan 3, 2011 at 4:51:35 AM | Schdule of Beam System
satheeshbabu
Hi,
I can not extract the data from the beam system. How Can I get schedule of Beam System?
Is there any Work around?
Please give a solution for this thread.
Thank You
Mon, Jan 3, 2011 at 11:17:21 AM | Schdule of Beam System
pdoug
3 Stars: 2 Votes
Would you be more specific as to what information you are trying to extract and schedule?
Tue, Jan 4, 2011 at 2:34:51 AM | Schdule of Beam System
satheeshbabu
Like Length and Width of the Beam system, Beam spacing etc.
Tue, Jan 4, 2011 at 5:45:13 AM | Schdule of Beam System
pdoug
3 Stars: 2 Votes
I would start by setting up your schedule to pull parameters from the beam system already in place - see attached pic.  The problem with trying to get a length and width of a beam system is you can have an irregular shaped boundary making up the beam system.  You could use the structural framing schedule to schedule lengths of individual members within the beam system.
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:21 PM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:11 PM
Beam System Tag
Fri, Aug 14, 2009 at 3:09:34 AM
beam system
Thu, Oct 15, 2015 at 7:32:18 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:49 AM
Page generation time: 0.3585
