47 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Imported Text Boxes from AutoCAD to Revit 2011 New Line Shifts Text Upward
Wed, Dec 29, 2010 at 4:52:32 PM | Imported Text Boxes from AutoCAD to Revit 2011 New Line Shifts Text Upward
zxinfinity
I'm working on a project where we've imported a bunch of text boxes arranged in a table from AutoCAD.  I'm not aware of how it was originally created, I just know that when I imported the CAD file, and exploded the drawing, I've been having strange issues with text.  I don't think they were MText objects, but rather Text objects.  In Revit, when I go to modify these text boxes, any new lines that I add are positioned where the original text was, and the rest of the text shifts moves upward.
 To my knowledge, the only way I know of to make Revit do this is to check the Keep Readable box, mirror the text box across a horizontal line.  When you do this, the 'move' and 'rotate' symbols appear below the text box.  My problem text isn't doing this, however.  I need to do this on hundreds (if not thousands) of lines.  Is there a way to mass-reset all of these buggy text boxes?
 I've tried Match Properties on a regular text box.  I've tried changing the style.  It seems as though there's a hidden property of these boxes that aren't accessible by Revit.  Any suggestions?
Wed, Dec 29, 2010 at 5:27:09 PM | Imported Text Boxes from AutoCAD to Revit 2011 New Line Shifts Text Upward
zxinfinity
I've found an article which suggests there ARE indeed Text Note properties that aren't readily accessible, or "official"...
http://thebuildingcoder.typepad.com/blog/2010/04/revitlookup-and-textnote-alignment.html
The question is, is it even possible to change them?
Autocad Text imported
Tue, Dec 4, 2007 at 9:29:15 AM
Black background on text (imported DWG)
Thu, Feb 18, 2016 at 8:38:48 AM
text box
Wed, Jan 7, 2009 at 4:47:43 PM
Cannot turn on leaders for text boxes inside custom annotation.
Wed, Aug 13, 2008 at 9:10:59 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:16 PM
Page generation time: 3.1389
