67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> view extents outside crop region
Wed, Dec 29, 2010 at 9:33:15 AM | view extents outside crop region
hunterfloyd
I can't seem to figure this out at all.  When I roll over any of my details in one particular project or any of my interior elevations on a sheet, the extents of the view are enormous, way past where the view is actually cropped.  Theres nothing shown in this huge extent(outside of the crop) but nevertheless it's really annoying to try to select a view on a sheet when they all overlap.  When I activate the view and attempt to find out what's causing this, it appears that my view is for some reason holding onto the extents of a wall that is in my view and also the room.  I've seen this happen many times with say an annotation of some sort that is way outside the crop accidentally, but never with a wall or room that has been cropped. What's even more confusing is that if I hide these elements that are invisibly extending past my crops, the view still gives me the huge extent when rolling over it...  any idears??
Thu, Dec 30, 2010 at 5:17:47 PM | view extents outside crop region
cganiere
cganiere Avatar
There may be an annotation off in  the distance. I found that in one project someone had adjusted a grid line or created a new grid line. Sometimes detail components have elements a bit away from the main geometry.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Sun, Jan 2, 2011 at 8:04:30 PM | view extents outside crop region
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've seen this before.  Make sure one of your families doesn't have something in it causing it to have massive extents.  I also try to avoid detail views, and use section view types or floor plan types only.  They just seem buggy to me sometimes.
Also, do an Audit on the file when opening, as it may indicate a small corruption in the database.  All model objects should conform to the crop region and all detail objects should conform to the annotation crop.  If they aren't then the crop is either disabled or something is corrupt in the file.  DWG files also sometimes don't conform to crop regions so remove any unrequired imports.
HTH.
Regards,
Chris.
Wed, Jan 5, 2011 at 12:13:57 PM | view extents outside crop region
hunterfloyd
I'm on the same page, I think it's either something embedded into a family or something embedded into a cad file(though i've deleted all my imports).  The same thing happens in my floor plan view if i minimize my crop a bit, so it's not the buggy detail view or section view.  I've audited the file and purged as well to no avail.
The strange thing is if I turn off "show annotation categories in this view" in "VV" it fixes it.  So I went through and turned off every annotation category one by one but that doesnt fix it when everything is turned off individually.  ANy ideas on a good way to find out what family could be causing it?
HuntFlo
Viewport extents reaching far beyond crop region
Mon, Sep 8, 2008 at 5:38:06 AM
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:30 PM
Crop Regions Disappear When I Assign a View Template
Sun, Apr 22, 2018 at 11:04:21 PM
Macro for changing lineweight of crop region
Wed, Jul 22, 2015 at 10:05:23 AM
View Extents in Revit 2019
Thu, Apr 11, 2019 at 9:09:56 AM
Page generation time: 1.7287
