78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How do you dimension to property lines?
Tue, Dec 28, 2010 at 11:34:57 AM | How do you dimension to property lines?
aozarski
I am trying to dimension the setbacks.  The dimension tool clicks on the property line but then it will not recognize the building (I get a / symbol).  Does anyone know how to do this?
Tue, Dec 28, 2010 at 11:44:59 AM | How do you dimension to property lines?
aozarski
I figured it out the property lines are not exactly parallel to the building.
Tue, Dec 28, 2010 at 12:28:05 PM | How do you dimension to property lines?
Good for you....
You do know that you can dimension from the property line to the corner of your building which would be your minimum setback?
Tue, Dec 28, 2010 at 12:55:33 PM | How do you dimension to property lines?
aozarski
Thanks, yeah that is what I ended up doing.
Property Line Dimensions
Tue, Jul 13, 2010 at 4:20:28 PM
Property Lines + True North Rotation
Thu, Apr 26, 2012 at 2:34:46 PM
Dimension Crop Box
Wed, Oct 21, 2015 at 3:17:52 PM
Property Lines on Toposurface
Mon, Jul 9, 2007 at 10:22:50 AM
property lines hidden by topography
Tue, Mar 6, 2007 at 11:47:48 AM
Page generation time: 2.4130
