58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Plumb Cut to ceilings
208 Posts No Rating |
Hi all,
When creating a sloped ceiling revit automatically plumb cuts the ends. How do I stop this from happening?
cadjockey
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
Unfortunately ceilings don't have the same options as roofs for the edges. So two options.
Do it as a roof...
OR create an in-place void family to cut the ceiling edge as required.
Hi Mr Spot,
That's a real shame. To have such a great tool and have it let you down at the post.
Anyway, If I create it as a roof will it show up on the ceiling plans and can I tag it on the ceiling plan appropriately?
Also, In using void sweeps to trim the edges of elements ie. roof/fascia junction, I am finding it very difficult to locate the void sweep once again in order to use it somewhere else. Sometimes the rollover finds it. Most times it doesn't. Is there another way?
cadjockey
Post edited on 2005-11-02 03:36:49
How to not plumb cut a graded slab |
Mon, Jun 20, 2011 at 2:02:18 PM
web joist and plumb cut |
Tue, Nov 29, 2005 at 4:48:03 PM
Pitch roof problems- double-plumb roofs with different height edges |
Thu, Feb 21, 2008 at 2:54:46 PM
Rafter cut different on each side of roof |
Tue, Jun 1, 2010 at 12:29:00 PM
Custom Rafter Cut for plumb plywood and square standing seam |
Sun, Dec 15, 2013 at 10:26:27 AM
Members: | 2022271 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
