88 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Titleblock with 2 stamps and editable text stacked?
Sun, Dec 26, 2010 at 1:37:41 PM | Titleblock with 2 stamps and editable text stacked?
bizz3d
I Have a Titleblock that I need to setup with 2 Stamps and editable text stacked on top of each other. The text will be on most of the time during DD set, ie. 60% 80%. Then I need to be able to turn it off and turn on one of the stamps. Depending on what engineer the project belongs to.
Our current setup we have them in layers within AutoCAD and turn them on & off, but I can’t figure out how to do that in Revit Structural 201
Sun, Dec 26, 2010 at 5:19:32 PM | Titleblock with 2 stamps and editable text stacked?
hhwse
I control the viability of my seal with a yes/no parameter in the title blocks.  I then make family types for title blocks with and without my seal.  This can be expanded to have families with different seals.
Wed, Dec 29, 2010 at 2:25:41 PM | Titleblock with 2 stamps and editable text stacked?
bizz3d
Can you please be more detailed on how to create it? I understand the concept but I dont know how to go about it. Ive done some shared parameters for items we required on the titleblock. Ive never had to add an "on/off" feature to one.
Thanks in advanced.
Wed, Dec 29, 2010 at 7:40:14 PM | Titleblock with 2 stamps and editable text stacked?
hhwse
I have created a link to a short video showing how to do it.http://screencast.com/t/3PYty5l4cfG0
Wed, Dec 29, 2010 at 11:11:32 PM | Titleblock with 2 stamps and editable text stacked?
bizz3d
Thank you so much for that. It was so easy but a pain. Thank you again; I can’t express enough gratitude for that video.
Thu, Dec 30, 2010 at 12:46:48 PM | Titleblock with 2 stamps and editable text stacked?
hhwse
One thing that I should add is that after setting the visibility in the last step, I create a group of the entire seal.  That way I can distinguish between the line work and text of the different seals.  If you need to edit the group, insert another copy of the group off to the side and edit that.  After you save the changes the original is changed and you can delete the copy. I use this technique for seals from different states.  If all that you are changing is the name and registration number you can just have that information in the yes/no parameter and not duplicate the line work which will help to keep the file smaller.  The yes/no parameter is very useful and I use it in a lot of my families.  For instance I create Simpson hardware by importing the dwg file from the Simpson web site and use the y/n to select which view shows.  Make sure you purge when you are done to get rid of the dwg file.
Mon, Jan 3, 2011 at 5:21:57 PM | Titleblock with 2 stamps and editable text stacked?
bizz3d
Thanks for the tip. If I have to send my project to an architect how do i protect the stamp? Would I need to create another titleblock without the stamp and then replace it? then maybe purge?
Mon, Jan 3, 2011 at 9:36:14 PM | Titleblock with 2 stamps and editable text stacked?
hhwse
I have a dummy title block with the same name that has all of the family types but the seal group is replaced with a circle.  Load it into the project and it will over-write the seal.
Help with some Titleblock issues... I just have a couple questions.
Sat, Sep 13, 2008 at 12:41:42 PM
newbie help with titleblock
Wed, Aug 23, 2006 at 8:11:14 AM
Titleblock elements on or off
Wed, Sep 3, 2008 at 8:52:10 AM
Titleblock text
Mon, Mar 27, 2006 at 4:15:20 PM
11
Titleblocks
Mon, Nov 1, 2010 at 6:59:16 AM
Page generation time: 2.1230
