Forums >> General Discussion >> Revit ROI >> Floor Plan View Disapperance
10 Posts No Rating |
I cannot see my floor plan views but I can see the section,elevation and 3D views. Has anyone had this problem? What can I do to get back my plan views?
Please be clearer when you ask your questions? Do you mean you don't have any plan views in the browser? Did you delete the views?
I have a project that list my views in the project browser but when I select the floor plan that I want to see the screen is blank. When I select the elevation veiws, the view can be seen. What could cause this?
Yes, the views are listed in the browser....
- The plan may be out of view - Type ZA for zoom all.
- You don't say what version you are on. Do you have all your updates installed?
you must also check view range in plan view and adjust its view depth and cut plan and so on
"Thank you Thank you!!!" ZA worked....
WW is genius,without knowing the software,he can answer the question..hehe
2 Posts No Rating |
I am having the same issue as JB 2010: I have floor plan views in my properties palette, but when I click on them, all I get is a blank screen. I have tried Zoom All and the view range appears to be in order. I have also tried re-making the views. The new floor plan view comes in blank. Elevations and 3d view are still there, as are some plan views that were already placed on sheets. Any other suggestions?
2 Posts No Rating |
Oops, ZA was working, I just still couldn't see anything once it was zoomed.
If you used ZA and the screen looks white, be aware that you have model objects at extreme distances from each other. Use a crossing window in the corners of your ZA window to find what these are. You probably have things you will want to remove.
