33 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Creating a wall paint color
Tue, Dec 21, 2010 at 2:52:02 PM | Creating a wall paint color
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I am currently working on a project that requires Zolatone for a wall finish and I can get the color off of the manufacturers website.  Is there a way to take the color I have saved as an image and make it a wall finish?  I could probably try it as a decal but I think it would get streched to much and end up looking bad.
Tue, Dec 21, 2010 at 3:25:00 PM | Creating a wall paint color
Can this site help you? http://www.easyrgb.com/index.php?X=TINT
Tue, Dec 21, 2010 at 3:32:56 PM | Creating a wall paint color
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't think so. Zolatone is the manufacturer, its a multi-color paint that spray applied and I can't find a multi-color option on that site.
Tue, Dec 21, 2010 at 5:51:57 PM | Creating a wall paint color
quinn
Is it a specific color or multicolored can you attach the image you have?
If it is a just an image go to photoshop record its RGB and then make a new material and enter in that RGB in the material.  If it needs to look a certain way in a render then make a new material in the render there is an option to attach an image.  Use that to go find your image and load it.  Now you can either attach the material to an element or paint it on a wall instead.
Wed, Dec 22, 2010 at 2:34:20 AM | Creating a wall paint color
gebber
gebber Avatar
5 Stars: 4 Votes
Just go to their site and copy the desired image/collor.
You can aply this image to a material.
You can also make a black and white image of it and aply this as a bump to make the surface of the material look more realistic.
(WWhub, great site by the way)
Wed, Dec 22, 2010 at 6:50:15 AM | Creating a wall paint color
Creating a material has been discussed in many posts.  This is a good one to start with: http://www.revitcity.com/forums.php?action=viewthread&thread_id=16048  And as gebber says, if you need a texture, you can create a bump file.
Gebber - yes, that site has some really nice tools.
Wed, Dec 22, 2010 at 8:08:22 AM | Creating a wall paint color
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Making it a bump looks great. Thanks for the help!
How can I paint the wall the color I want?
Thu, Apr 3, 2008 at 6:59:35 AM
Changing Wall Paint color
Sun, Feb 7, 2010 at 7:02:40 PM
Paint Help
Wed, May 22, 2013 at 5:33:21 PM
How to add paint color to wall
Mon, Mar 8, 2010 at 4:30:47 PM
Tag elevation by color
Tue, Apr 14, 2009 at 1:45:54 PM
Page generation time: 1.8256
