63 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Architectural Work Flow
Tue, Dec 21, 2010 at 1:16:54 PM | Architectural Work Flow
joeinck
Using Revit 9.0 Building. My question is in regards to the typical work flow of a new building.  As we know, Architects move between Schematic Design, Design Development, Construction Docs continuously throughout a project. It would be nice to keep an active 'view' that contained the rendered design while moving forward with CDs. Changes in the CD set would be reflected in the DD view so it stays current, but the rendering that shows on a DD drawing would not appear on the CD drawing. Was easily done using xrefs in straight autocad. Are worksets the best way to approach this?
Creating an attenuator family - air flow problem
Wed, Jun 13, 2012 at 4:16:11 AM
Revit MEP/ ARCHITECTURE Work flow
Fri, Sep 18, 2009 at 10:42:26 AM
Piping flow arrows
Thu, Jan 20, 2011 at 5:40:31 PM
AIR FLOW GOING THE WRONG WAY
Wed, Jun 4, 2014 at 12:01:12 PM
Domestic Hot water - No flow
Fri, Dec 11, 2009 at 3:50:05 PM
Page generation time: 1.0704
