Forums >> Revit Building >> Technical Support >> import to revit from autocad
4 Posts No Rating |
Hello, I want to import dwg file (autocad 2011) which contains only property lines to revit 2009. But I always get " some elements were lost during import. ActiveX or some proprietry components cannot be imported. Try exploding the file in Autocad, or setting proxy graphics to 1." I think the problem is the version because there was no problem before using autocad 2011 instead of autocad 2008. Can anyone help me to achieve this? Thank you so much in advance.
Before you import that file into Revit you must clean the file, delete all hatch, text, explode polylines and blocks then purge the file.
4 Posts No Rating |
Please don't consider this issue. I solved the problem. I saved the autocad file as autocad 2007 in files of types option then Import was successful.
1 Posts No Rating |
Thanks
This also worked for me
1 Posts No Rating |
Yes, this also worked from me! THANKS!!!!!!!!
Autocad Import Problems |
Tue, May 5, 2009 at 1:55:33 PM
Revit Crash when Autocad Site plan Import |
Wed, Jan 7, 2009 at 4:51:26 PM
Import topo surface from AutoCAD to Revit?? |
Thu, Oct 17, 2013 at 12:49:05 PM
Autocad import problems |
Thu, Jan 20, 2011 at 1:54:38 AM
import revit renderings into autocad |
Mon, Jan 17, 2011 at 2:18:17 PM
Members: | 2105144 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
