Forums >> Revit Building >> Technical Support >> Tile Window ... horizontally??
148 Posts No Rating |
The Tile Window (WT) command is quite useful for many chores, but if there are only 2 windows, it will always tile 'vertically'. Does anyone know how to change this to default to a 'horizontal' layout of the tiled windows? (and yes, I know that I can do it manually ... :o)
Ian Shafer
Principal Consultant
True North S&F Consultants |
No
Hey, check out this site http://wiip.biz/content/revit-arrange-windows-horizontally
Weird my two windows tile side by side ?
There is a free add-in. Hit ‘top’ or ‘bottom’ layout and adjust the window size you want. It will remember the settings next time you press ‘top’ or ‘bottom’. Check other options as well – kinda neat.
in tab mode, grab the tab of one of the open views and drag & 'place' it (like you're locking the properties or proj browser tab horizontally) over the unused part of the tab bar. i use it to pop two open views into horizontal tile mode. you might have to try it a couple of times to work/get the hang of it.
Revit tile/ window is blank |
Sun, Jun 10, 2018 at 4:15:20 PM
Tip for Window tile and zoom all |
Wed, Sep 16, 2015 at 2:38:18 AM
Can Door/Window cut through multiple walls |
Fri, Jun 1, 2012 at 1:45:27 PM
Roof Tile Material..... Monier Life Tile |
Mon, Oct 31, 2011 at 2:15:23 AM
24" Tile |
Thu, Aug 25, 2011 at 8:17:40 AM
Members: | 2100554 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
