37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> SECTIONS AND LEVELS
Mon, Dec 20, 2010 at 10:58:51 AM | SECTIONS AND LEVELS
Bimman
Bimman Avatar
1 Stars: 2 Votes
I JUST LAID IN A SECTION MARKER AND FOR SOME REASON MY LEVELS ARE NOT SHOWING UP.  THIS IS THE FIRST TIME THIS HAS EVER HAPPENED.  EVERYTHING IS TURNED ON ION THE VIEW, SO I SHOULD BE SEEING THEM. BUT THEY ARE MISSING.  ANY IDEAS? SPENT THE LAST HOUR TRYINH TO FIND THEM.
PWD
Mon, Dec 20, 2010 at 11:14:22 AM | SECTIONS AND LEVELS
3.5 Stars: 395 Votes
Are you sure the extends of the level cross the section?  Levels are only visible if they are cut by the view.
Mon, Dec 20, 2010 at 11:42:17 AM | SECTIONS AND LEVELS
Bimman
Bimman Avatar
1 Stars: 2 Votes
THAT IS WHAT IT WAS, BEEN USING REVIT SINCE 04 AND THAT IS THE FIRST TIME THAT HAS EVER HAPPENED TO ME.
 THANKS
PWD
Mon, Dec 20, 2010 at 2:15:42 PM | SECTIONS AND LEVELS
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Wow, that's surprising.
Levels and Grids have to be cut by the view to display in the view.
Plan views have a cut plane and view range that have an impact.
Sections and Elevations have clipping planes.
Then there are scope boxes.
Mon, Dec 20, 2010 at 3:05:06 PM | SECTIONS AND LEVELS
Bimman
Bimman Avatar
1 Stars: 2 Votes
guess i must have always been lucky and put sections in the correct spot.
PWD
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor and Ceiling Levels
Sat, Jul 15, 2006 at 9:38:55 PM
VISIBILITY OF LEVELS
Tue, Jul 13, 2010 at 12:45:49 PM
levels in sections/elevations
Tue, May 9, 2006 at 11:18:21 AM
What is your standard for anotating levels
Mon, Nov 10, 2008 at 12:40:39 PM
Page generation time: 6.1329
