56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Sloped wall parapet caping
Mon, Dec 20, 2010 at 5:27:25 AM | Sloped wall parapet caping
gastonverdicchio
 Hi there,
I'm trying to add a metal caping to a sloped wall. I know that i have to create a solid form sweep and apply it to the sloped wall. My question is: Does anybody know  how to do this in a very step by step basis because I am easy to be lost in the mid way.
Regards,
Gaston
Mon, Dec 20, 2010 at 5:40:37 AM | Sloped wall parapet caping
4 Stars: 201 Votes
You must use an "In-Place" family, go to Home > Component > In-place , choose the category, in this case Wall, now you will see at the top "Solid Sweep", use ""pick path" and select the edge of that wall, close the path and select "edit profile", sketch the profile like you want and finish the profile, also, you can assign a Material to this parapet.
Look at the bottom of this page and you will see similar threads.
Also, I post this a couple years ago: http://www.revitcity.com/forums.php?action=viewthread&thread_id=14444
I don't know if the video still active but...
Edited on: Mon, Dec 20, 2010 at 5:50:48 AM
Thu, Dec 23, 2010 at 5:00:05 AM | Sloped wall parapet caping
gastonverdicchio
Hy Typhoon,
Many thanks foryour assiatance , really worked. My question now is how to link this sloped wall with a straight wall (both with caping) please see attached,
Regards,
Gaston
Thu, Dec 23, 2010 at 8:11:34 AM | Sloped wall parapet caping
3.5 Stars: 395 Votes
Do all the walls with the in-place family.  HINT.... start in the middle of a wall and end ther - not at a corner.  If you start at a corner, that corner will not be joined.
This user is online
Thu, Dec 23, 2010 at 1:14:29 PM | Sloped wall parapet caping
4 Stars: 201 Votes
Create the Sweeps then use the "Join Geometry" tool between them.
Thu, Dec 23, 2010 at 1:36:52 PM | Sloped wall parapet caping
4 Stars: 201 Votes
BTW, here you have the file so you can take a look
Merry Christmas
Thu, Jan 6, 2011 at 3:03:10 AM | Sloped wall parapet caping
gastonverdicchio
 Hi Mr. T.
Have a happy new year. Many thanks for the file that you have sent to me I'll have a look to it,
Regards,
Gaston
Tue, Jan 11, 2011 at 4:20:00 AM | Sloped wall parapet caping
gastonverdicchio
Hi Typhoon,
The coping thing really worked many thanks for that,
Regards,
Gaston
Parapet wall sweeps at corners with different wall thicknesses
Thu, Feb 7, 2013 at 11:00:38 AM
Help-Parapet Wall
Thu, Mar 10, 2005 at 4:22:16 AM
So how do I do this? Adobe walls
Fri, Mar 7, 2008 at 12:17:14 AM
R2008+9: Parapet flashing to a wall with an editted profile
Tue, Jan 8, 2019 at 8:00:02 AM
Problem with roofs and parapet walls
Thu, Mar 29, 2007 at 4:55:44 PM
Page generation time: 0.8181
