82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> How to compute formwork
Fri, Dec 17, 2010 at 8:38:43 PM | How to compute formwork
rcgold23
Hi guys, just want to ask if some one knew about computing some beam formworks and slab formwork? are there any possible way of computing it? or any tips and recommendations? thank you in advance.. Smile
Fri, Dec 24, 2010 at 12:27:47 PM | How to compute formwork
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I am assuming that you are speaking of designing form work for poured in place concrete, these must be designed by an engineer for all anticipated loads. Including vertical horizontal, equipment and men, etc. Not a simple task as you may be just realizing.
Sat, Mar 17, 2012 at 3:00:07 PM | How to compute formwork
Klauss
Hi! i tried this last month but we only get the total surface area for formwork(shuttering)
but hopefully this will help.
for the beam, make a material take off and get the material area, u will notice that the surface area(4sides) of the cut beam by the slab are computed. so u need to make a formula to deduct the upper face attached to the slab because you dont need to put a formwork there.
for slab, do the ssame thing make a material take off and get the material area, u will notice that all the surface of the soffit will be computed. so you need to deduct faces of beams, columns & walls that are attached to your soffit.
How do i create Formwork for walls and slab using revit architecture.?
Mon, Jun 14, 2010 at 11:58:17 AM
can't align family
Wed, Feb 5, 2014 at 9:40:01 AM
Buyng New Computer for Revit 2012
Wed, Oct 26, 2011 at 9:29:08 AM
Volume stair computation
Thu, Dec 9, 2010 at 9:55:03 PM
Calculate Pile cap girth (Perimeter)
Thu, May 2, 2019 at 2:49:05 AM
Page generation time: 0.2297
