57 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Image in Shaded view walkthrough
Thu, Dec 16, 2010 at 10:49:00 PM | Image in Shaded view walkthrough
JcMc
Hi Gang,We’re currently doing a walkthrough to be seen in Shaded mode - no rendering. On one of the walls that is along the side of a stair, there is to be seen a poster / fresco, and our graphic artist has drawn it up and made a .jpeg of it. We’re having a bit of trouble. 2 issues with it. (We’re inerting it as an image and not a Decal as the final product won’t be rendered)
1. We’ve gone to an elevation of the wall it’s to be on, set the reference plane to the surface of that wall and the image then sits behind the walls surface. When I do a Draworder to bring it forward, it comes too far forward and then screens out the stair balustrade as well.
2. When we do to the Walkthrough Window and look at that wall it doesn’t seem to show anyway.
Got any tips?
Fri, Dec 17, 2010 at 1:09:56 AM | Image in Shaded view walkthrough
tim123
4 Stars: 19 Votes
The image that you insert will only be visible in the elevation, so you won't be able to see it in the walkthrough.  You will need to render it and use the decal.
Sun, Dec 19, 2010 at 5:52:00 PM | Image in Shaded view walkthrough
JcMc
Thanks for that Tim. That's a pity about it not being seen in a shaded walkthrough. In fact it seems to be only available in that view that it's inserted into. :-/
Thu, Nov 19, 2015 at 5:56:41 PM | Image in Shaded view walkthrough
sllana
5 Stars: 2 Votes
U CAN SEE IT IN REALISTIC
Rendered Walk through
Mon, Nov 22, 2010 at 4:58:08 PM
walkthrough
Wed, Aug 1, 2012 at 5:43:43 PM
Rendered Walkthrough
Thu, Jun 7, 2007 at 7:39:51 AM
walkthrough questions
Mon, Mar 25, 2013 at 2:44:09 PM
tree in shaded view
Thu, Jul 31, 2008 at 1:37:04 PM
Page generation time: 1.3512
