64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> sweep angle on door
![4.5 Stars: 3 Votes](/images/stars_4.5.gif) |
I am tracing drawings from autocad into revit v8.1 and have come across a problem. The door shown in the attached file has been designed so that it does not open the full 90 degrees. Can somebody explain to me how this can be achieved in revit.
Many Thanks
![4 Stars: 5 Votes](/images/stars_4.gif) |
Hi Nathan,
I think you have to create a new door family and adjust the swing in the family to suit
Will
3 Posts No Rating |
if you are running Revit 8.0, select the door family and chose to edit familily. remember to SAVE AS the family with a difrrent family once in family envirolment, go to floor plan view and edit the door sweep angle to desired , remember its just the 2d symbolic lines on the floor plan, it has nothing to do with the 3d geometry. Hit upload to project on the lecft pane select your project from the pop up list, go now to your project select the door again and change family type to the new one from your family dropdown. Good luck.
3D in place sweep problem, changes angle |
Mon, Jan 28, 2008 at 12:56:37 PM
Generic line based sweep |
Mon, Jan 28, 2013 at 5:06:38 AM
Door angle |
Thu, Aug 25, 2005 at 4:41:59 PM
Help with parametric sweep |
Sat, Dec 11, 2010 at 3:46:46 PM
Chairail on an angle |
Wed, Jun 22, 2011 at 3:29:35 PM
Members: | 2016928 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
