150 Users Online (148 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> align pipe to a revit family
Thu, Dec 16, 2010 at 2:50:16 AM | align pipe to a revit family
maenhoudtbrecht
Hello,
 How can I align a Revit family with a pipe in Revit Mep?
The problem is not how to align it. But when I change te parameters of my family the pipe will not adapt.Is there a solution for this?
 Thanks in advance
Thu, Dec 16, 2010 at 9:35:22 AM | align pipe to a revit family
jackhoward
You will need to provide more detail to get the answer to this question, but if you wish to align it, the family must have a plumbing connection.  If that is the case, the easiest way I have found to align pipe and the family is to use the align tool in a 3d view and click on the end of the pipe (a dot will appear in the middle of the end of the pipe) and then click on the plumbing connection within the revit family (again a dot will appear).
 Hope this helps
Fri, Dec 17, 2010 at 1:45:54 AM | align pipe to a revit family
maenhoudtbrecht
By this the problem in detail(simple explenation).
We have a pipe trough a wall.  When we go trough the wall we a have stainless steel plate on the wall.This is needed in clean area's. So the pipe goes know trough the plate on the wall. This means we can't use pipe connectors.
 For the plate we make a family.
It isn't a problem to align them at this moment. But when we after aligning move the plate, the pipe stays at the same place.
Fri, Dec 17, 2010 at 10:13:09 AM | align pipe to a revit family
jackhoward
I don't think there is a way for Revit to automatically do what you are trying to do without putting a pipe connection in the family. You will have to manually move the pipe to adjust to where you put the plate.
Dimensioning tolerances to use align dimension with grid lines ?
Tue, Feb 9, 2016 at 11:18:31 AM
Issues with Pipe elevation tagging
Mon, Aug 24, 2015 at 8:23:32 AM
Parametric Pipe Fittings Family Modelling Problems
Fri, Jan 12, 2018 at 3:44:31 AM
pipe dimensions
Wed, Dec 2, 2015 at 7:47:04 AM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:46 AM
Page generation time: 4.9614
