40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walls - Incorrect tile shown - Revit 2011
Tue, Dec 14, 2010 at 3:08:28 PM | Walls - Incorrect tile shown - Revit 2011
forlando
I have walls currently drawn in my model (Revit 2011) that had a 4x4 tile pattern assigned to the wall type.  I have since updated this 'place holder' tile pattern with the one we're actually using consisting of at least 3 different bands of tile including a base, a standard wall tile, and a border tile.  The wall is the correct type and has the correct properties but the pattern didn't update in all locations.
If I click on the problem wall and 'create new' the same type wall is drawn and the tile is correct on the new wall but if I do this for each wall I run the risk of losing wall hosted equipment as I'm re-hosting and transfering info.  I've tried matching properties, switching to a different wall entirely and switching back, I've checked if the walls are painted or if there are any overrides happening in the visual display, and they're all in the same phase... I can't seem to figure out what's going wrong.
I've attached 2 images showing the problem... any suggestions are welcome - Thanks!
Tue, Dec 14, 2010 at 3:49:20 PM | Walls - Incorrect tile shown - Revit 2011
How did you create your "correct" wall?  I normally do these as a stacked wall (thin - just a tile thickness) that I place against my gyp bd wall and join to it.  Or did you do this somehow else?
Tue, Dec 14, 2010 at 4:05:34 PM | Walls - Incorrect tile shown - Revit 2011
forlando
I use a basic wall, split the region of the finish tile layer, create a new layer, assign it to the region I just split, and give it a material assignment.  This keeps the tile the same thickness throughout and allows me to assign different tile patterns per our design.  The horizontal lines on the incorrect wall are the break marks built in to the wall structure of where the correct tile patterns should be, and when you click the properties of that wall it says that the wall layers are as they should be.
The odd thing is that the incorrect wall is the exact same wall from our component list as the other, correctly tiled wall... clicking on them simultaneously shows that they're two of the same.
I've attached a screen shot of my wall construction.
Wall Types and Materials are not shown in Revit 2011
Mon, Apr 25, 2011 at 9:34:28 AM
Walls Not Shown In Ceiling Plan
Wed, Aug 25, 2010 at 9:12:46 AM
Stair to landing connection shown incorrect in section
Mon, Sep 20, 2010 at 11:40:15 AM
Tile and Revit 2009
Tue, Jun 24, 2008 at 3:24:47 AM
Flooring Tile setting out
Tue, Jun 18, 2013 at 3:59:03 AM
Page generation time: 2.9781
