64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Rebar Schedule
Tue, Dec 14, 2010 at 8:40:56 AM | Rebar Schedule
ESCOZA
5 Stars: 2 Votes
I noticed that when I set up my rebar schedule it takes the measurements from outside dia to outside dia of the rebar. Is there any way to change it to centerline-centerline?
Tue, Dec 14, 2010 at 8:44:56 AM | Rebar Schedule
gdoherty0102
3 Stars: 2 Votes
What measurments is it taking from outside dia to outside dia?  I am assuming you are talking about the spacing?  What type of rebar are you using?  I.e. Area, Path, or "Rebar"?
Tue, Dec 14, 2010 at 8:53:38 AM | Rebar Schedule
ESCOZA
5 Stars: 2 Votes
I am using sinle layout rebar. when i use the schedule to detail out the rebar dimensions A dimension B dimension C for example when there is a bend it measures to the outside of the bend instead of the centerline of the bend.
Tue, Dec 14, 2010 at 8:59:27 AM | Rebar Schedule
gdoherty0102
3 Stars: 2 Votes
You would have to manipulate your rebar bend families to change that, and even then I am not sure you will be able to as there is not much freedom to bend families or bar families.
I am curious as to why you want to change this to centerline rather than outside dimension, bend standards (at least here in the USA) have those dimensions A, B, C, etc going to outside face just as Revit has it.
Thu, Oct 4, 2012 at 6:12:39 AM | Rebar Schedule
nate1hardrada
iTS NOT STANDARD PRCTICE IN THE FEILD TO MEASURE REBAR FROM CENTER TO CENTER DO TO CLEARANCE ISSUES. ALLWAYS MEASURE OUT TO OUT,  BECAUSE YOU ARE PLACINF REBAR "IN" CONCRETE NOT NEXT TO CONCRETE.
REBAR SCHEDULE HELP!!!!!!!!!!!!!!!!!!!!
Thu, Oct 4, 2012 at 6:15:25 AM
Rebar Schedule - Right click to Show rebar in View - I see no "Show... " option
Sat, Nov 22, 2014 at 3:28:11 PM
rebar schedule ????
Tue, Feb 7, 2017 at 10:34:19 AM
How to add unit weight as a parameter in rebar schedule?
Thu, Oct 4, 2012 at 6:19:37 AM
Revit 2016 - Rebar note
Wed, Jul 29, 2015 at 9:21:12 AM
Page generation time: 11.0173
