60 Users Online (59 Members):
Forums >> Revit Systems >> Technical Support >> Calculated Value
![alabaster2513 Avatar](user_avatar/28262.jpg)
![3.5 Stars: 25 Votes](/images/stars_3.5.gif) |
Does anyone know if there is a character limit to Calculated Values in Panel Schedule Templates? I am trying to do an extremely large condition statement but Revit seems to be cutting on my formula half way through....
side note: Revit help for 2011 blows... it never finds anything. I'm usually all for change but only when it works right
![brettgoodchild Avatar](user_avatar/14257.jpg)
![4 Stars: 17 Votes](/images/stars_4.gif) |
I was told that it is the same limit as excel...in which case it's like 32,000 and some change. Never tested to see if it is actually true or not. I would type what you need in notepad and paste it into the formula and see if it works. you can see from the image attached that I was able to cram a lot of characters into the formula
Yeah I have it written in notepad, its long but not that long.
Calculated Values in Room Tags |
Wed, Mar 30, 2011 at 4:08:03 PM
Calculated value |
Fri, Aug 6, 2010 at 2:17:19 PM
Calculated Values |
Mon, Mar 20, 2006 at 12:58:54 AM
Calculated totals of formula in schedule |
Fri, Sep 11, 2020 at 7:14:07 AM
How can I create calculated sloping ductwork, with elbows? |
Sun, Feb 18, 2018 at 3:12:08 AM
Members: | 2017168 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
