Forums >> General Discussion >> Wishlist >> Update Inserted DWG
If I have to insert a dwg into a family, I would like to at least be able to manually update it instead of reinserting every time.
lunch .... that is why you use link instead of insert.
I am trying to figure out a clever way to link a dwg with blocks of devices layed out... then somehow have Revit replace the blocks with specified families. Not sure if or how, but I am determined to find a way.
wwhub, in families not projects.
Sorry lunch - read it too fast. I don't like 2D CAD imports in families. I think those should always be revitized. I do recognize that some 3D elements just don't model well in Revit so I will use sketchup or other CAD 3D forms.
yea, it isn't really by choice. i've got this massive 3d dwg from a consultant and wish there was another way. It just seems so easy to make it so that I could select the dwg import, click an update button in the properties, and point it at a dwg file. revit could just use the same 0,0 point and voila! done.
Locking inserted image/dwg file |
Mon, Aug 29, 2011 at 9:38:25 AM
Reference DWG disappearing when zoomed |
Mon, Jan 2, 2012 at 2:28:43 PM
inserted dwg view problem in 2013 |
Tue, Oct 29, 2013 at 5:24:27 AM
Why does my Imported .dwg dance??? |
Thu, May 11, 2017 at 6:33:51 AM
11
Rendering has permanet stripe material from inported 3D DWG |
Sun, Oct 18, 2009 at 10:53:32 PM
Members: | 2101676 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
