66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How do I use this Guardrail Profile in the Rialing Tool
Mon, Dec 13, 2010 at 7:38:51 AM | How do I use this Guardrail Profile in the Rialing Tool
cboersen
I downloaded the Guardrail Profile listed below
http://www.revitcity.com/downloads.php?action=view&object_id=1676
 It says to use it with the Railing tool but it apears to oly be a detail component.  How do I make this work?
Mon, Dec 13, 2010 at 7:45:20 AM | How do I use this Guardrail Profile in the Rialing Tool
3.5 Stars: 396 Votes
It is a profile - just use that for one of the rails in a railing description.  To see how this is used, download the sample projects ... railings ... from the on-line location here: http://revit.autodesk.com/library/html/index.html
That railing may already exist there.  If not, I'm sure you can find something similar that you can change.
Mon, Dec 13, 2010 at 8:19:00 AM | How do I use this Guardrail Profile in the Rialing Tool
cboersen
Got it.  Thanks.
Interrupted Guardrail with Continuous Handrail - Revit 2013
Thu, Feb 20, 2014 at 12:16:31 PM
Complex Guardrail
Mon, Sep 15, 2008 at 10:53:48 AM
Adaptive Railing with Handrails
Thu, Sep 3, 2015 at 9:11:18 AM
Need gate to match stair guardrail
Fri, Aug 25, 2017 at 6:38:03 AM
Stairs w/ Guardrail to Code
Sun, Apr 4, 2010 at 8:51:51 AM
Page generation time: 0.4384
