44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Creating a horizontal recess in a vertical grooved plywood clad wall (SORTED)
Mon, Dec 13, 2010 at 5:24:15 AM | Creating a horizontal recess in a vertical grooved plywood clad wall (SORTED)
Pele
Pele Avatar
I managed to sort out this query on my own (usually the best way)
I made a new profile & I did not realise that I was using the wrong term for what I wanted to achieve, should have called it a sweep. Anyhow here is the result.
Can anyone tell me how to create/reduce Revit files so that that they are small enough to upload here?>??
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Fri, Dec 10, 2010 at 3:49:12 AM
vertical plywood
Fri, Nov 25, 2011 at 8:26:45 AM
12
Vertical Plywood Hatch Pattern [ 1 2 ]
Mon, Aug 27, 2012 at 4:04:31 PM
17
Horizontal curtain walls
Tue, Feb 28, 2012 at 9:57:12 PM
Grooved reducer
Thu, Aug 26, 2010 at 12:33:04 PM
Page generation time: 1.2594
