64 Users Online (63 Members):
Forums >> Revit Systems >> Technical Support >> Changing template to project
2 Posts No Rating |
Hi there, I started a project with mass modeling and i continued with Revit template by mistake. I'm in the middle of the project and I want to change it to the project. It is not possible by "save as". It is so appreciated if you can help me. Thanks,
You are in the middle of the project in a "Mass" template? What kind of project is that? you didn't need walls, door, floors, windows, and so on? What you can do is create a new project and load that "Mass Project" to the new project.
2 Posts No Rating |
Actually I started with conceptual mass, cause of the irregular shape of the building and this is an architectural project. I found my problem when I didn't see the file in recent list while I open the Revit. First I thought it is a bug but I got this is a Revit template file I created by mistake. I put the walls doors curtain walls and other stuff in this template. Now I need to change this template to project. There is a way saving as a project to the template but there is not any way for reverse action.  If you could find any way you can help me to save the time!
Just start a new project and use this file as your template would work.
Changing a template to a Project |
Tue, Feb 2, 2010 at 7:03:23 AM
Changing a Template |
Mon, Jul 8, 2013 at 2:44:42 PM
how to convert a template to project file in 2012 |
Fri, Aug 2, 2013 at 2:58:22 AM
Changing .rte template midstream |
Thu, Feb 14, 2008 at 1:03:47 PM
Template to Project |
Tue, Jul 31, 2018 at 2:25:32 AM
Members: | 2081118 | Objects: | 23122 | Forum Posts: | 152272 | Job Listings: | 3 |
