83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Aray in Families - Trusses
Fri, Dec 10, 2010 at 3:47:13 PM | Aray in Families - Trusses
zoommby
I was browsing through the existing revit families in my imperial library.  I noticed a device they use on several of the trusses is to array the web members.  As the truss size is changed in the model bays will be added and eliminated according to the length.  Pretty nice feature.  Can you direct me to any tutorials or explain how this is done?
Fri, Dec 10, 2010 at 5:34:43 PM | Aray in Families - Trusses
lunchtrayrider
3.5 Stars: 7 Votes
you can add a parameter to an array.  an equation such as     =Length/5'+1  would divide a length by 5' and add one (for a minimum of 2 in most cases)
help should cover this, the help also lists a lot of information about equations and parameters.
I like scooters. and motorcycles.
Fri, Dec 10, 2010 at 11:52:39 PM | Aray in Families - Trusses
zoommby
Thanks I'll get into the help files.  I assumed they didn't go into that kind of depth.
 zoommby
Structural trusses invisible when rendered in 3d camera vew
Sun, Oct 3, 2010 at 12:15:20 PM
Trusses
Fri, Mar 18, 2011 at 10:04:58 PM
adding trusses
Tue, Jun 29, 2010 at 7:14:27 AM
Creating trusses
Thu, Dec 29, 2016 at 6:44:10 AM
Ref Planes
Mon, Dec 5, 2005 at 7:11:45 PM
Page generation time: 0.4644
