71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Column Tag Visibility
Fri, Dec 10, 2010 at 3:05:57 PM | Column Tag Visibility
jennamajerus
I am trying to create a single column tag file that will show the tag at 45 degrees either right-up, right-down, left-up, or left-down.  Right now we have each of those as their own family and it seems to be more of a hassle.  I want to set them up as "instance" perameters rather then "type" so I can change the orientation if necessary to a specific column tag.  I believe I have everything that I need set up properly but when I load it into my project and I go to my properties box, I don't see my list of perameters for turning stuff on and off.  If I change my perameters to "type" I can go into my type properties and see them there but for some reason I'm not seeing them as and "instance" property.  Or maybe this isn't possible for tagging thing, I don't know.  So if someone could help me out and point me in the right direction that would be wonderful. Thanks.
Sat, Dec 11, 2010 at 7:04:07 AM | Column Tag Visibility
Type tags are easy to use.  I suggest you tag all of your columns.  Then en-mass, select each one that you want to flip and switch them to the other type all together.
COLUMN BASE ELEVATION - TAG
Tue, Dec 2, 2014 at 1:25:38 PM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:01 AM
Column Volume in Tag
Tue, Oct 4, 2011 at 1:53:32 PM
TAG A COLUMN THAT HAS BEEN MODELED IN PLACE
Tue, Oct 26, 2010 at 10:48:02 AM
column grid visibility
Wed, Nov 15, 2006 at 3:43:14 PM
Page generation time: 1.3909
