54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> copy new level
Mon, Oct 31, 2005 at 3:38:28 PM | copy new level
why8888
i am new to revit, ex ArchiCAD how to copy a level to next level? if they are all identical. how to adjust the stair handrail when you draw stair with boundary or run? you do not have to do adjust after you created? why8888
Mon, Oct 31, 2005 at 4:18:29 PM | RE: copy new level
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Welcome to the wonderful world of revit. 1. Select element on one level, copy to clipboard, paste aligned by level and pick all the levels that you wish to paste the elements... 2. Select the handrail and edit the sketch or change its type if need be. Of course you can edit things after they are created. HTH.
Mon, Oct 31, 2005 at 6:31:02 PM | RE: copy new level
eldados
eldados Avatar
4.5 Stars: 8 Votes
regarding stairs, you can also change your stair to be a multi level stair, if the height between levels is the same, you can run it all the way up. just go to stair properties and tick multy level and the desire level...
Integrator
KarelCAD
Can't copy furniture group to different level view
Thu, Jun 7, 2018 at 10:43:55 AM
copy groups from level to level
Fri, Feb 5, 2010 at 7:55:07 AM
Copy Dimensions
Fri, Oct 10, 2008 at 7:26:59 AM
Aligning grids the same in each level?
Fri, Sep 23, 2005 at 11:13:40 PM
Revit Architecture 2012 - Copy/Mirror Changes Component levels
Wed, Feb 6, 2013 at 2:01:46 PM
Page generation time: 3.7135
