39 Users Online (38 Members):
Forums >> Community >> Newbies >> heloo and some questions
26 Posts No Rating |
Heloo every one! im new to revit but trying to addapt to it realy quickly as our office is taking a drastic step to mostly using revit for our projets. huraa! currently im trying to put to gether a set with plans and sections and an area schedule. question: how do i make all my section annotatopns exacly the same for each level. i have to change the head for each level and if i drag the head to further along the axis the change is not reflected in the other levels thanks
What do you mean you have to change the head for each level? Basically, Revit places the same annotation everywhere it affects based on the initial location. From then on, any adjustment is considered to be view specific.
so if i change the length of a section on one level how do i get the same lenght on the second floor? do i use referance lines and eyeball it or just create a new section?
When you place the section, and if the section extends vertically through other levels, it will initially show up the same as created on every affected view - plans and elevations. You can never create another callout of a view except by using the "reference other view" setting.
i created a section that is different leghts in different plans. its only the annotation part that is different though, not the crop box. so basically if i flip through the plans it jitters like crazy.
Please state Revit version being used in your questions [ 1 2 ] |
Thu, Dec 15, 2016 at 6:32:17 AM
21
noob with questions and some experience |
Sun, Oct 4, 2009 at 5:21:38 AM
Basic Questions |
Wed, Dec 16, 2009 at 1:01:10 AM
PME questions and is this the proper forum for PME questions? |
Wed, Mar 11, 2009 at 3:28:33 PM
Multiple Newbie Questions |
Mon, Sep 23, 2013 at 8:47:23 AM
Members: | 2056535 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
