48 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> projection vs. cut lines
Mon, Oct 31, 2005 at 2:01:47 PM | projection vs. cut lines
arccodex1
3 Stars: 1 Votes
Besides determining the line width what other functions do cut/projection lines serve? I was hoping maybe you can turn on or off cut/projection lines in Visibility Graphics but it doesn't look that way. Post edited on 2005-10-31 14:25:55
Mon, Oct 31, 2005 at 2:13:54 PM | RE: projection vs. cut lines
TomDorner
4.5 Stars: 25 Votes
The cut and projection styles determine the display of your objects in the model in projection and cut views. How could you turn off these displays? If you did then you wouldn't see anything in your plan or section view. What is it in specific that you are hoping to accomplish? What you seem to be asking for does not make logical sense. Tom
Mon, Oct 31, 2005 at 2:29:39 PM | RE: projection vs. cut lines
arccodex1
3 Stars: 1 Votes
Sometimes features in Revit have alternate uses/functions. I just thought I'd ask. I haven't need to to turn off projection or cut lines yet. Someone might want to turn off projection lines if all they wanted to show was the cut section. I guess this could be achieved by altering the visibility depth. Post edited on 2005-10-31 14:31:34
why my projection lines overlap cut lines.
Tue, Apr 10, 2018 at 7:41:08 PM
Toggle cut and projection lines
Tue, Mar 6, 2012 at 6:57:57 AM
Visibility Projection and Cut lines.
Wed, Nov 5, 2014 at 1:55:04 PM
Projection and CUT
Sat, Nov 24, 2012 at 5:07:00 AM
Projection Lines - Too Many Lines With Curves
Tue, Jun 3, 2008 at 7:32:06 AM
Page generation time: 0.6310
