70 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cannot cut below grade sections with any depth after topography placed
Wed, Dec 8, 2010 at 2:13:26 PM | Cannot cut below grade sections with any depth after topography placed
avrjjoe
5 Stars: 2 Votes
Hi,
When I insert topography into Revit 2010, the portions of my building that are below grade cannot produce section cuts with any depth. As in, if I cut through a stairwell that runs from the basements up through to the roof, the floor above grade show the rails in the distance that I allowed in the section cut view distance, but once the building goes below the grade line, all distant object vanish, and I am left with only the objects that the cut line itself is passing through. This goes away if I delete or hide the topo. Based on assumption, I think maybe the topo is considering everything below the grade to be solid earth, and so it is showing me that beyond the section line is solid, non-transparent earth. Is there a way to either set the topo to only show me the surface grade line in section view? I can hide the earth hatch easily enough in Visibility Graphics or even in the material setting, but I think Revit still acknowledges that there is non-transparent Earth there. How can I create a surface topo without any earth mass below it?Thanks all!-Joe
I edited this post to change the text size to a readable font.  -wwhub
Edited on: Wed, Dec 8, 2010 at 3:19:24 PM
AECOM - Have we swallowed your firm into our collective yet? Resistance is futile.
Wed, Dec 8, 2010 at 3:20:54 PM | Cannot cut below grade sections with any depth after topography placed
Yes, Revit will not automatically make room for your structure below grade.  You have to cut the topography or use a pad.  You can read about PADS in your HELP or search the forums - PAD.
Mon, Jun 20, 2011 at 3:56:39 PM | Cannot cut below grade sections with any depth after topography placed
avrjjoe
5 Stars: 2 Votes
This issue was solved! Thanks again WWHub!
http://www.revitcity.com/forums.php?action=viewthread&thread_id=24464
linked file visability and cut depth [ 1 2 ]
Thu, Jul 13, 2017 at 3:23:18 AM
16
Using topography to cut an object
Thu, Jun 1, 2017 at 6:52:01 AM
Revit Topography schedule - several issues!
Mon, Jul 14, 2014 at 8:59:00 AM
CUT AND FILL - PADS WHICH DO NOT SHOW C&F VOLUME ON A SCHEDULE
Tue, Feb 13, 2018 at 4:37:06 AM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
Sun, Dec 2, 2012 at 7:34:52 PM
Page generation time: 1.3564
