29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Custom Trusses in Revit
Tue, Dec 7, 2010 at 6:00:42 PM | Custom Trusses in Revit
zoommby
I am trying to frame roofs using Revit Architecture 2011.  I am using a warren with cambered top chord truss - 10 panel from out of the box.  My problem is it creates a symetrical truss and I need a truss that has the same pitch on boths sides but the right side is a diffrent height than the left side.  I tried using cut which allowed me to trim the top and bottom chord but then I have members which are comipletly outside of the cutting plan so I cannot trim them out.
Thanks Zoomby
Fri, Dec 10, 2010 at 10:12:10 AM | Custom Trusses in Revit
TeamNga
1 Stars: 1 Votes
Hi.
Im not sure what you need exactly but I attached two example I created in 5 minutes. Take a look at it and see if it helps you out. I started these families from the structural truss template in revit.
Just remember to lock up webs and dimensions properly if you want it to work.
If you have any questions let me know.
Fri, Dec 10, 2010 at 11:11:36 AM | Custom Trusses in Revit
zoommby
Those examples are great.  After working with them I realize one of the problems with the out of the box trusses is autodesk has deleted all the dimension information from their trusses so they won't work as a starting point for a custom truss.  Your example solves this for me so thanks I appreciate it.
Zoommby
Creating trusses
Thu, Dec 29, 2016 at 6:44:09 AM
Roof Trusses
Wed, Dec 23, 2009 at 6:56:52 AM
Trusses in Revit Architecture
Tue, May 20, 2014 at 3:53:36 PM
Roof Trusses
Fri, Apr 11, 2008 at 10:19:15 PM
I am having trouble loading the structural trusses
Thu, Oct 7, 2010 at 3:58:09 PM
Page generation time: 2.4584
