66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Wall design help please
Mon, Oct 31, 2005 at 1:43:59 PM | Wall design help please
zeppelin6230
Hello, im a 9th grade student who is currently take a dessign concept class. One of my assigments to create a home in the stlye i that was asigned to us. Lucky me got Tudor stlye home and was wondering if any one had any good ideas or tutorails to help me with the exterior wall design....ty and happy desgining Post edited on 2005-10-31 13:45:22
Mon, Oct 31, 2005 at 1:46:43 PM | RE: Wall design help please
larryhoops98
hi, dylan how are you?
Mon, Oct 31, 2005 at 1:47:51 PM | RE: Wall design help please
zeppelin6230
i m fine larry but only post if you can helpm me with my problem
Mon, Oct 31, 2005 at 2:08:55 PM | RE: Wall design help please
TomDorner
4.5 Stars: 25 Votes
What specific problem is it that you are having? The Tudor style will probably require the use of sweeps on the exterior walls. If you can provide some specifics on where you are getting stuck someone will be able to help you out. Tom
Mon, Oct 31, 2005 at 2:23:19 PM | RE: Wall design help please
zeppelin6230
just strating off from the begin Post edited on 2005-10-31 14:23:35
Mon, Oct 31, 2005 at 6:32:41 PM | RE: Wall design help please
eldados
eldados Avatar
4.5 Stars: 8 Votes
post a sketch of what you want and someone will help... who knows, maybe I will Smile
Integrator
KarelCAD
Tue, Nov 1, 2005 at 1:30:53 PM | RE: Wall design help please
zeppelin6230
i would like to add the sweeps such as in the picture below on the tudor stlye home. I know who to put in the sweeps but are confused about how to make the apear going up and down istead of just left to right www.teacherstravelweb.com/salisbury.jpg enter this in browser for a quick picture
Tue, Nov 1, 2005 at 4:10:02 PM | RE: Wall design help please
TomDorner
4.5 Stars: 25 Votes
You can do a combination of wall sweeps horiz and vertical, or it may be easier to just do an inplace family on each wall face. I did a quick sample one you can reverse engineer. I placed a reference plane on the front wall named it, did an in-place family by going to 'model' 'create' and did extrusions for the Tudor boards. Hopefully this will get you going in the right direction. Tom
Tue, Nov 1, 2005 at 5:34:01 PM | RE: Wall design help please
eldados
eldados Avatar
4.5 Stars: 8 Votes
hmmm... I would do it as curtain wall with mullions as your "stuck on" members. this will be the easiest way, and replace your panel glazing with the wall you need... HTH
Integrator
KarelCAD
Wed, Nov 2, 2005 at 1:06:45 PM | RE: Wall design help please
zeppelin6230
thanks for your tips, tom the sample you gave me i cant open because it was svaed in a later version of revit and cant be opend on revit 6... if you could same how could make it work would help out alot to see if i create the wall correct
Thu, Nov 3, 2005 at 2:05:50 PM | RE: Wall design help please
#11
zeppelin6230
I FIGURED IT OUT!....ty for all the help
Design Option Error
Wed, Mar 19, 2014 at 12:28:03 PM
WALL SWEEPS WITH DESIGN OPTIONS
Mon, Dec 3, 2007 at 2:28:10 PM
Wall cleanups in design options
Mon, Mar 2, 2015 at 11:41:52 AM
design option question
Mon, Mar 1, 2004 at 7:46:17 AM
Design Options
Wed, Dec 24, 2003 at 10:33:51 AM
Page generation time: 1.3022
