Forums >> Revit Building >> Technical Support >> cutting walls with void revolve component in revit 2011
3 Posts No Rating |
I'm working through Mastering Autodesk Revit Architecture 2011. The current objective (project organization-page 29) requires me to cut a series of spiral walls with a revolved component. I cannot get the cut tool to select the component. What am I doing wrong?
Just click on "Cut Geometry" tool and select the void and a wall then repeat until you cut all walls then you can finish the family.
3 Posts No Rating |
If i leave the model unfinished i can select the void with the cut tool but not the wall afterward. If i complete the model it wont let me select the void at all with the cut tool. Did I maybe make the void wrong?
After you cut the first wall use the "TAB" key to select again the VOID then select other wall... tab, tab, tab...
3 Posts No Rating |
Thanks for your help. I had the type set to solid rather than void and am still getting used to changing attributes with the new side menu. A second look at the your first illustration and it clicked.
9 Posts No Rating |
did you ever get that revove issue figured out.
I have been reading the same book and am having the same problem as you had.
Please let me know how to get all the walls selected.
shapeing top of walls with void revolve |
Tue, Feb 12, 2013 at 4:01:01 AM
using revolve tool to shape top of walls 'Revit 2012' |
Wed, Feb 20, 2013 at 2:47:55 PM
Void Forms cut Revolve not successful and remove the line |
Fri, Mar 11, 2016 at 8:03:37 AM
Void Forms and other questions |
Tue, Jan 11, 2011 at 8:22:47 AM
Cutting irregular openings in curved walls |
Sun, Apr 9, 2006 at 7:45:39 PM
Members: | 2105604 | Objects: | 23178 | Forum Posts: | 152303 | Job Listings: | 3 |
