49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> a set of families
Mon, Dec 6, 2010 at 5:10:31 PM | a set of families
SteveB
3.5 Stars: 5 Votes
Is there a way to save, import or "transfer project standars" an entire family group (found in the project browser) out to another project?
Example:  i have loaded a whole lot of families into a project and customized a bunch too: example...all the lighting fixtures for a certain type of project (residential, commercial).  This ends up being a standard group of selections you want to have available in a new project.  Or some other strategy
Tue, Dec 7, 2010 at 9:29:23 AM | a set of families
kbeegles
I'm guessing that there is probably a better way than this, but you could try:
1 - Create an instance of each family that you want to export.  Create one instance of each type within each family.  It doesn't matter where or how you create them, as long is it is located somewhere in the project.
2 - Save the project file and then link it into the project that you want to transfer the families to.
3 - Convert the linked project to a group by clicking on it and then hitting "Bind Link".
4 - All of the families in the link should now appear in the project browser.  You can delete the group and the families will still be present.
Hopefully that gets the job done for you.
The Leffler Group
Tue, Dec 7, 2010 at 10:04:48 AM | a set of families
TKennedy
4 Stars: 7 Votes
kbeegles' method will work to get your families into current projects, but if you're going to need them in every new project you will need to put them into your project template.
Tue, Dec 7, 2010 at 10:09:56 AM | a set of families
kbeegles
Agreed...template is definitely the way to go with new projects.
The Leffler Group
How can a get a parts count for a set of families?
Tue, May 20, 2008 at 6:59:12 AM
Line Weigths in Families
Sun, Feb 21, 2016 at 6:51:46 PM
Changing the detail level in a large group of families......
Mon, Aug 26, 2019 at 4:44:53 PM
Families, how do you do it?
Thu, Mar 31, 2011 at 2:38:46 PM
car and tree families for plan, section and elevation drawings
Mon, Apr 21, 2014 at 9:34:09 AM
Page generation time: 0.7803
