70 Users Online (69 Members):
Forums >> Revit Building >> Technical Support >> Import DWG problem with size
5 Posts No Rating |
I have a dwg file that is in millimetres. When I try to import I get message.....cannot import because it would create revit model that is larger than 2 miles across. I have import units set to auto detect, however when I change these to meters, I get the same message. Any assistance would be greatly appreciated.
![mbsteve Avatar](user_avatar/23553.jpg)
![4 Stars: 13 Votes](/images/stars_4.gif) |
Is this a survey? may be due to origin distance from actual object
5 Posts No Rating |
Thank you for your assistance. The file was a survey created by third party and on closer inspection the z co-ordinates were all over the shop. I fixed these and the file imported no problems.
Revit 2010 Dwg. Import problem |
Thu, Sep 2, 2010 at 1:52:03 AM
Can't import dwg or dxf to RS2008 |
Wed, May 30, 2007 at 10:36:07 PM
.dwg import problem |
Tue, Sep 6, 2011 at 7:48:54 AM
dwg importing problem |
Wed, May 28, 2008 at 8:52:30 AM
Import DWG in Family - Problem!!! |
Fri, Sep 28, 2007 at 2:31:36 PM
Members: | 2016934 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
