161 Users Online (159 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Nested void geometry doesn't cut host solid
Mon, Dec 6, 2010 at 8:35:14 AM | Nested void geometry doesn't cut host solid
Stopher
Im trying to create a family with a parametric array of void geometry, in order to get the array parameters working correctly it needs to be nested, however when it is loaded into the host family it will not cut the solid geometry. i can't seem to figure out what im doing wrong, can someone help please?
Mon, Dec 6, 2010 at 8:52:56 AM | Nested void geometry doesn't cut host solid
Before you finish any void, you have to define the host that it cuts.  How did you create the void?  Perhaps you should use a face hosted void where the void cuts the host face.
Mon, Dec 6, 2010 at 9:11:16 AM | Nested void geometry doesn't cut host solid
Stopher
Tried that too, doesnt work.  ive tried a lot of different options like this but just can't make it work. Could it be the case that voids in nested families just do not cut geometry in host families that is not a system family?
Mon, Dec 6, 2010 at 12:41:21 PM | Nested void geometry doesn't cut host solid
4 Stars: 203 Votes
What are you trying to cut?
Mon, Dec 6, 2010 at 3:18:43 PM | Nested void geometry doesn't cut host solid
shaverjeff
Stopher,
Nested families are capable of cutting geometry within a host family, as long as the nested family is face based.
I believe the standard families (non-face based) will not allow you to cut a host with a nested void.
Try creating your parametric void array as a face based generic model family.
Use Nested Void Family to Cut Host?
Sat, May 28, 2011 at 10:39:48 AM
void form and cuttng void form
Fri, Jul 9, 2010 at 12:39:02 PM
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
Void extrusion wont cut mass
Wed, Nov 21, 2007 at 11:27:01 PM
VOID FORM says there is no geometry to cut.... [ 1 2 ]
Wed, Dec 17, 2008 at 12:52:27 PM
19
Page generation time: 5.1942
