50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> REVIT 2011-STAIRS SETTINGS.
Sun, Dec 5, 2010 at 11:48:37 PM | REVIT 2011-STAIRS SETTINGS.
terrywu218
terrywu218 Avatar
Hello,
I have big problem on stair settings.
1 story=4 meters. The elevation of stairs in AUTOCAD is shown in the first screen of 2nd floor. Stair numbers contains 24 including the last step to story floor. But in the revit, when I set level (1st, 2nd), riser heght 166.7,it's shown  23 numbers instead, and the last step shows 4 meters as story floor.
Could any one tell me how to set the parameters? I need the model shown exact elevation like autocad, the plan is as same as autocad though.
Mon, Dec 6, 2010 at 1:45:56 AM | REVIT 2011-STAIRS SETTINGS.
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
change the formula inside the revit stair type. 2 riser+1 step= x. You need to change the X. And adjust the start with riser/end with riser.
Exporting Revit Architecture 2011 Custom Settings
Sun, Dec 12, 2010 at 10:40:15 PM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
monolithic stairs
Thu, Mar 15, 2012 at 11:34:58 PM
Revit 2020 - Stairs not showing in plan levels
Sun, May 29, 2022 at 7:23:51 PM
Stairs connecting properly...
Mon, May 2, 2011 at 3:55:39 PM
Page generation time: 1.6207
