56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Turning off sweeps in an elevation view?
Sun, Dec 5, 2010 at 1:30:55 PM | Turning off sweeps in an elevation view?
treeves1968
I have custom parametric casework families that I have built from scratch. They employ a void sweep on the faces of the doors to create a realistic cabinet for rendering purposes in 3DSMax. The problem is, when I go to do interior elevations in Revit, all the sweeps are ofcoarse visible. Is there any way to turn off the sweeps in elevation views? Amy help would be greatly appretiated. I am using Revit 2011 Architecture x64.
Mon, Dec 6, 2010 at 7:25:23 AM | Turning off sweeps in an elevation view?
In the family, you can control visibility of individual items for plan /elevation / section.
Mon, Dec 6, 2010 at 8:27:47 AM | Turning off sweeps in an elevation view?
treeves1968
Yes,I tried that. I highlighted the sweep while in the family,went into "visibility"and turned it off in "Front/Back" and reloaded it into a project. But they continue to show up. Am I doing somethin wrong here?
Mon, Dec 6, 2010 at 8:54:49 AM | Turning off sweeps in an elevation view?
I think your problem is that it is a void and the cut geometry is still visible.  That too would have to be turned off.
Mon, Dec 6, 2010 at 9:05:04 AM | Turning off sweeps in an elevation view?
treeves1968
Oh ok. I was just hoping that there was a way to just turn off the void as if it didnt exist and show the solid geometry as it was before the void. Oh well, I guess it was wishful thinking. Thank you for your reply.
Turning off one view title tag without turning them all off
Thu, Feb 22, 2007 at 6:27:43 AM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:40 PM
Problems tagging wainscottting wall sweeps
Wed, Jun 20, 2012 at 2:34:38 PM
Revit Linked View is turning to Host View after Synchronizing
Thu, Feb 23, 2017 at 3:32:40 PM
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View
Tue, Jul 22, 2008 at 9:38:25 AM
Page generation time: 1.6941
