43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Revit 2011 Rendering stops at 50%
8 Posts No Rating |
I am trying to render a project on Revit 2011 at best quality. Although it takes some time, everything seems to run fine... until the render progress indicator reaches 50%. Once it reaches 50% the renderer inexplicably stops, and the progress indicator closes as if it thinks it is finished. It is not as if the computer freezes, it just acts as if it is finished, but only at 50%. Has anyone else had this problem? I think I may just need to reinstall.
Is an Exterior or Interior render? With Artificial lights only or Sun light only? What's the the size of that file? Did you install the Web update? what's the SPECs of your machine (RAM and so on)?
8 Posts No Rating |
The machine I'm using is not my main machine, just another computer that I can let render while I work on other things on my other computer. It's an AMD Athlon 64x Dual Core Processor, 2 Gigs of Ram (I know, not much), and video card is NVIDIA GeForce 6150SE nForce 430. The specific render is a fairly easy one of a rendered axon view... exterior sunlight only. I've tried it on several quality levels... all the same result. I don't know if something happened because it was working fine before Thanksgiving and now it just stops after 50 percent. As for the web update? I don't think I've heard about that before... I'm an architecture student so I am using the free student version of 2011.
"... 2 Gigs of Ram (I know, not much),..." - I'm surprised how can you work..., watch this: http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=12431819 And here you have the Web Update: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973244
Walkthrough rendering stops [ 1 2 ] |
Mon, Feb 22, 2010 at 4:30:51 AM
17
REVIT ARCH 2011 render problems |
Fri, Sep 16, 2011 at 2:04:13 PM
Render stops after finalgather pass on larger images |
Thu, Apr 15, 2010 at 9:48:34 PM
Revit 2011 renders on 75DPI but not on 150 DPI |
Wed, Nov 28, 2012 at 5:48:09 PM
Rendering in Revit 2009 [ 1 2 ] |
Thu, Dec 31, 2009 at 10:41:31 AM
19
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
