62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> window family creation
Fri, Dec 3, 2010 at 8:24:03 PM | window family creation
lightshadows23
Im not sure how to do this and so to not do it wrong way..
basically I tried new--> family and then selected metric window
but then i tried to load into project with all ways possible and it just didnt load..why?
if there are any usefull threads i havent read please let me know .thanks
Sat, Dec 4, 2010 at 5:21:51 AM | window family creation
4 Stars: 202 Votes
Did you have any kind of error when you "load into project"? After you create the window save it then load into project and place to a wall, or, go to Home > Windows and in Properties select that window OR in project browser expand Families > Windows and select the window and "drag" to the wall.
Sat, Dec 4, 2010 at 9:28:29 AM | window family creation
lightshadows23
aa I tried again and now it works. so before I may have created something else.
but I cant figure out how to make what i want . something like the image attached. it will be basicaly wood blank window and then I want to cut triangular shapes off.. when i created mass I could work on vertical way too. in families I cant even figure out how to copy the work plane:S
please can someone explain to me?
if you could send me any information pdf's that would be great
Sat, Dec 4, 2010 at 9:55:28 AM | window family creation
4 Stars: 202 Votes
If the wall is flat just "Edit profile" that wall and draw the shapes you want like you can see in the images attached and create a "Automaticaly Embed" curtain wall , if the wall is in curve you must use a "In-place" family (VOID) in the category wall to create that effect.
Sat, Dec 4, 2010 at 10:33:32 AM | window family creation
lightshadows23
thanks typhoon!
also this video helped alot  http://www.youtube.com/watch?v=TDWxRgC_oA0
its easier to choose wall based family and change parameters to window than do it with window family
family creation request form
Wed, Jun 30, 2010 at 1:20:14 PM
To Window Tag or not to Window Tag...?
Thu, May 21, 2009 at 12:33:24 PM
Family creation tutorials?
Tue, Mar 3, 2009 at 4:12:10 AM
window frame family + nested window frame fill
Wed, Apr 12, 2006 at 7:31:30 AM
adding mass in family editor or in place family creation
Thu, Nov 23, 2006 at 9:52:52 AM
Page generation time: 0.8778
