54 Users Online (53 Members):
Forums >> General Discussion >> Revit Project Management >> How can i present my Revit model on screen
3 Posts No Rating |
Hello Revit People ![Smile](/images/smiles/smile.gif) I want to know if there is a way you can present revit to a client on screen. how can you disable the blue falshing lighting when you touch on elements? if there a program to help do that? i have tried to turn off the lighting but couldn't, i am left with using sketchup to present which is a program that i really hate thanks!
![4 Stars: 7 Votes](/images/stars_4.gif) |
You mean the highlight? You may be able to change it to a less annoying color in Options, but I don't know how to shut it off (I really doubt that you can). Something else to look at if all you need is to present your model is exporting to a DWF and using Design Review (free DWF program from Autodesk).
![nastyclown Avatar](user_avatar/114560.jpg)
![4.5 Stars: 9 Votes](/images/stars_4.5.gif) |
You can export revit models to Dwf. Then tell your client to dowload the (free) dwf viewer. http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=4086277 Play a while with it, its very related to BIM. Btw, you can present 2d views aswell.
![3 Stars: 2 Votes](/images/stars_3.gif) |
DWF works, but I tend to lean towards using Navisworks instead. And since one of the versions of Navis is free (a viewer) it works just as well!
![itsmyalterego Avatar](user_avatar/109615.jpg)
For the first time, we've presented revit models/walkthroughs as a streaming screen capture accompanied by a teleconference to clients a thousand miles away. "Gotomeeting" or some service like that. That way, they didn't have to make any large downloads, and we were able to direct the movement from our end. It was a big success. Nothing impresses clients more than being able to fly around the interiors at a conceptual stage.
3 Posts No Rating |
Thanks everyone, those were all helpful replies and work to a degree. However i tried everything and still won't work the way i wanted it. what i wanted to do is present my work on my laptop connected to a projector, if only i could zoom orbit and pan without the blue highlights flashing. one thing i was able to do though was create mass in place and present while that mode is running that turned all edges white and the highlights stop flashing, however that still takes away from the design intent. i wish Autodesk can develop a presentation mode where you can navigate regular with just the highlights off thanks again everyone
Fly screen doprs!? |
Fri, Dec 15, 2006 at 4:50:25 PM
revit not working properly on large screen |
Tue, Sep 14, 2010 at 11:39:49 AM
Dots appear on screen When Shados are turned on |
Thu, Aug 14, 2008 at 4:16:16 PM
help for import sketchup file into revit |
Tue, May 29, 2012 at 2:21:24 AM
help with family parameters to show colours in elevation views. |
Tue, Nov 30, 2010 at 7:14:20 AM
Members: | 2026371 | Objects: | 22993 | Forum Posts: | 152208 | Job Listings: | 3 |
