84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> tagging curtain wall doors
Thu, Mar 25, 2004 at 8:11:46 AM | tagging curtain wall doors
Tzu0
tried this question in another forum, couldn't get any clarification. maybe someone can help? I have inserted double glass curtain wall doors on the shopfronts. now, I want to tag the double doors so that i can see it in my door schedule. How do you tag the doors since the door tags only appear when you insert the door? In the schedule, it recognizes the double glass and single glass doors but does not give it a mark or type? why? Help
Thu, Mar 25, 2004 at 8:58:18 AM | RE: tagging curtain wall doors
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
you can tag doors using the "tag" tool under the "drafting" tab. There could be a number of things wrong with the schedule to not show mark or type. Make sure the schedule has those fields applied to it.
Hiroshi Jacobs
Tue, Mar 30, 2004 at 4:34:14 PM | RE: tagging curtain wall doors
skisouth
5 Stars: 3 Votes
just checked again, I've got the same issue. I understand what your asking I think. You have created a curtain wall and replaced the system panel with a door type for the curtain wall. You go to tag it and you get a curtain wall tag. I don't think you can force the door tag onto the curtain wall door. We'll have to look for a work around, unless there is a solution I haven't found yet. - Anyone else...
Tue, Mar 30, 2004 at 5:00:41 PM | RE: tagging curtain wall doors
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
all you have to do is use the "tag" tool on the drafting tab. the tag snaps in place to the curtain wall door. At least it does in 6.1
Hiroshi Jacobs
Tue, Mar 30, 2004 at 5:08:11 PM | RE: tagging curtain wall doors
skisouth
5 Stars: 3 Votes
Perhaps thats the key. In 5.1, the door is listed in the door schedule, but not on the floor plan.
Tue, Mar 30, 2004 at 5:55:37 PM | RE: tagging curtain wall doors
Steve_Stafford
5 Stars: 2 Votes
The TAB key is your friend, start the tagging command, hover over the door curtain wall panel, press tab until the door is selected.
Tue, Mar 30, 2004 at 9:40:28 PM | RE: tagging curtain wall doors
skisouth
5 Stars: 3 Votes
obviously been up tooooo long. Thanks for the reminder. Use it day in and day out on other selections. Totally brain dead on this one. Works like a champ. Thanks.
Mon, Jul 30, 2007 at 3:14:12 PM | tagging curtain wall doors
notagain
notagain Avatar
4 Stars: 1 Votes
we have tried this...but we keep getting the edge of the frame and then we have to put the number in manually...what are we doing wrong
I really want this to work...some good things some bad
tagging a curtain wall
Tue, Nov 9, 2010 at 2:10:01 PM
Curtain wall doors
Mon, May 4, 2009 at 2:05:35 AM
Curtain wall doors wont center up
Mon, Oct 12, 2009 at 4:28:49 PM
No curtain wall doors on curtain walls!
Sun, Nov 22, 2009 at 7:10:59 PM
deleating doors from project and tagging problems
Thu, Dec 4, 2014 at 2:04:11 AM
Page generation time: 0.7513
