64 Users Online (63 Members):
Forums >> Revit Structure >> Technical Support >> Can I change materials and render appearance on components from revit city?
1 Posts No Rating |
I've downloaded some components from revit city (chairs, tables, etc.) and I put them in my project. I would like to set a material and render appearance for them so they look a certain way in rendered views. How can I do this? Thanks for your help
![nastyclown Avatar](user_avatar/114560.jpg)
![4.5 Stars: 9 Votes](/images/stars_4.5.gif) |
All the components must have a unique material name for each material. That means if you change the appareance in the family , must change in the Proyect. Kinda. Well, its not going to change. You have to change inside the revit proyect. You can do it easier isolating the family ( use the glass icon on the tab where you change the coarse/medium/fine appareance) and hitting render. After you have the look you need, reset the glass thingy. Its very recomendable to load the family to a "Test proyect" instead of your actual proyect.
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ] |
Fri, Aug 8, 2008 at 6:11:21 PM
31
Render Appearance Library - Reloading |
Wed, Mar 18, 2009 at 1:04:31 PM
New Render Appearance |
Tue, Jul 6, 2010 at 9:45:22 AM
Render familie |
Thu, May 15, 2008 at 10:16:41 AM
Revit crushes Materials |
Thu, Mar 17, 2011 at 7:30:57 AM
Members: | 2016890 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
