72 Users Online (70 Members):
Forums >> Revit Structure >> Technical Support >> -ve value for a length parameter
25 Posts No Rating |
Hi, I create a structural framing family with type of parameter as length. I can not give negative value for the parameter. How to give negative value for a parameter? Thank you.
Sorry, but how can anything have a negative length?... I understand what you are asking but obviously, all lengths have to be positive so knowing that, you should understand that your problem is your reference point. Add a new reference plane if you have to but dimension this element in such a way that it will always be a positive number.
OK, I created a reference plane and I gave double the value for that parameter and I achieved. Thank you for your reply. ![Smile](/images/smiles/smile.gif)
Can a Yes/No Parameter control a Length Parameter? |
Thu, Mar 22, 2012 at 12:17:27 AM
'Inconsistent units" error in parameter formula; length vs integer |
Fri, Dec 13, 2013 at 10:37:04 PM
Length Parameter |
Mon, Mar 17, 2008 at 10:44:55 AM
Creating a Beam Family Where Each Type has a Determined Length |
Wed, Aug 31, 2016 at 11:55:27 AM
11
Family Instance Parameter Dimension Help |
Wed, Apr 10, 2013 at 5:22:09 PM
Members: | 2017161 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
