37 Users Online (36 Members):
Forums >> Community >> Newbies >> error when loading components
34 Posts No Rating |
when i try to load some componenets (and it does seem to be random) i get the error message as per the attachment. can anyone shed any light how i might resolve this?? thanks.
I would get that error too if I were trying to load a model element while in a detail element load. Under the annotate, component tab, you can only load detail or annotation families.
This just means your not loading the appropriate file type. For example, if I go the "column" and then "load family" and if I try to select a mechanical device, this message will pop up. For the example you provided, you probably were trying to load a curtain door after going to the 'Door' command. Curtain wall doors are different. You have to make sure your under the right category.
Thanks DeifyMe That now makes sense - much appreciated. Kind regards j12ebr
Problem loading components |
Mon, Sep 28, 2009 at 3:43:40 AM
problem loading components |
Sun, Apr 26, 2009 at 2:21:18 PM
Fatal error inserting components |
Mon, Nov 24, 2008 at 7:26:38 PM
Loading downloaded components into project |
Wed, Aug 1, 2012 at 9:14:43 AM
problems loading detail components |
Mon, Jan 29, 2007 at 3:54:18 PM
Members: | 2056535 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
