62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> HOW DO I PRINT MY JPEG IMAGE?
86 Posts No Rating |
Hi there, I have inserted an image (jpeg) into my title block, and it appears fine on screen, but will not print. It's a raster image, I've put it in the 'foreground' but don't have any options to play around with visibility settings or anything. I'm using Revit 2011 - any ideas? Have read a few similar questions on the forum but haven't had any luck so far..... Thank you
Are you printing in "Vector" or "Raster" mode? try to use PNG images instead of JPEG's.
Hey I'm printing in Raster with jpegs, shoud I try printing in raster with png? Or Vector using png files? I usually have jpegs so would like to figure out how I can print using jpgs - whats the best format to use? Thank you for your help
I know this post is a little late, but I'm running 2012 and suddenly am having this issue.
The image in my titleblock file doesn't print at full size in either vector or raster mode. It does print on the small printer for letter and tabloid size prints. My work-around was to insert the image on every sheet in my project file, rather than in the titleblock family, and it printed fine. Only problem is that if I create a new sheet, I have to remember to copy the image over.
Not sure why this started happening in this new version. I still have projects that I started in 2009 that I continue to use in 2009 (others in the office don't yet have 2012 on their computers) and do not have this issue.
I saw the thread on Autodesk about downloading a hotfix, but it didn't work.
dfitzladdy - We are also having the exact same issue within our office at the moment.
If you figure out how to fix it, I'd greatly appreciate any suggestion that may help.
Thanks in advance.
Just an update guys.
I decided to further my research with this issue and found the solution on the autodesk discussion groups.
Here is the link for anyone interested:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13666326&linkID=9243099
6 Posts No Rating |
raja15, thanks for following up with this. I'm working in Revit 2012 and my plotter is a KIP5000, so your post doesn't quite do the trick. However, it inspired me to start messing around with the KIP's printing preferences, and I changed the Output Format to be "KIP Script" instead of "KIP GL" and it solved the issue.
Assigned a jpeg image to one material and other have it too |
Fri, Jul 10, 2015 at 7:30:33 AM
jpeg image in 3-d view |
Mon, Apr 21, 2008 at 11:23:03 AM
JPEG image from titleblock not showing... |
Thu, Mar 22, 2012 at 3:11:26 PM
Print at Scale via Jpeg |
Fri, Jun 27, 2014 at 1:07:03 PM
Printing image problems |
Wed, Jun 15, 2011 at 12:01:40 AM
Members: | 2056212 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
