67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Expanding the Materials Library
Hi to all, I was wondering if anyone knew if it were possible to bring into Revit's material library some external materials/shaders. I'm crossing over to Revit from ArchiCAD where this process was quite simple. I've got more than $500 of Arroway textures that I want to piut into Revit and render out with the Mental Ray - but as yet I've not found out how to import them. I'm guessing that once loaded, it would be relatively easy to make up the elements with luminance / bump maps / etc.; it's just getting them there that the issue for me! Many thanks in advance. Andy
"I'm crossing over to Revit from ArchiCAD where this process was quite simple" - in Revit is quite simple too, just go to Materials duplicate a Default material then in Render Appearence you can load the texture (image) you want, difuse, bump....
Thanks Typhoon, sounds simple enough; I'll give it a go now!
How to get more Materials in the library (Revit Architecture 2012) |
Fri, Jul 8, 2011 at 1:01:21 PM
REVIT 2013 Materials Library Video Tutorial |
Tue, May 28, 2013 at 5:12:56 AM
13
materials |
Sat, Nov 29, 2008 at 6:09:56 AM
Custom Material Library Problem |
Wed, Nov 13, 2013 at 4:18:49 PM
2018 Revit Materials Library |
Thu, Jun 1, 2017 at 12:44:37 PM
Members: | 2042200 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
